PirateMikey
Nov 11, 2018Tutor
X Box Live Connect Issues with Orbi Router
Having issues with my X Box One S connecting to X Box Live. All services are up and running; XB network settings showed connected to Internet, but cannot connect to XB Live Service. Per Microsoft, ...
Nov 11, 2018Guru - Experienced User
What FW is currently loaded?
How many game consoles do you have? Just the one?
uPnP is all thats needed to gain access to all of XBL services.
How is the xbox connected to the Orbi?: Wired or wireless?
Set a IP address reservation for the xbox ON the router.
Hard Power OFF the xbox console then power it back on. Hold the power button until it turns off.
- PirateMikeyNov 11, 2018Tutor
What FW is currently loaded? V2.2.1.210
What is the Mfr and model# of the ISP modem the NG router is connected too?Arris TM1602 (Spectrum)
Two; XB One S and PS4 (haven't tested PS4; room mate doesn't use it much)
currently wired; however issue also occured on wireless
Done - one for each MAC address.
BRILLIANT! It's in! Thanks so much. This product is so nice and the user community is the best.
Thanks, again!
PirateMikey
- HappymanpanMar 09, 2019AspirantI’m confused I just purchased the orbi and orbi satellite but I can’t connect to xbox live and have the same problem you did and not sure what to do
- FURRYe38Nov 11, 2018Guru - Experienced User
I would hold in the power button until it turns off. Then do a full reboot of the ISP modem and Orbi router. After it's all back to ready, power ON the xbox and check IP address and NAT status. IT should be OPEN in network settings an in a game.
