PirateMikey
Nov 11, 2018Tutor
X Box Live Connect Issues with Orbi Router
Having issues with my X Box One S connecting to X Box Live. All services are up and running; XB network settings showed connected to Internet, but cannot connect to XB Live Service. Per Microsoft, ...
PirateMikey
Nov 11, 2018Tutor
What FW is currently loaded? V2.2.1.210
Arris TM1602 (Spectrum)
How many game consoles do you have? Just the one?
Two; XB One S and PS4 (haven't tested PS4; room mate doesn't use it much)
uPnP is all thats needed to gain access to all of XBL services.
How is the xbox connected to the Orbi?: Wired or wireless?
currently wired; however issue also occured on wireless
Set a IP address reservation for the xbox ON the router.
Done - one for each MAC address.
PirateMikey
Nov 11, 2018Tutor
BRILLIANT! It's in! Thanks so much. This product is so nice and the user community is the best.
Thanks, again!
PirateMikey
- HappymanpanMar 09, 2019AspirantI’m confused I just purchased the orbi and orbi satellite but I can’t connect to xbox live and have the same problem you did and not sure what to do
- FURRYe38Mar 09, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router by chance? If so,Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Is the Orbi system operating in Router or AP mode?How is the xbox connected? Wired or wireless?
After the Orbi system is setup, power ON the xbox console. Hold the power button until the console shuts off. This resets the networking on the console. Powre it on.
Happymanpan wrote:
I’m confused I just purchased the orbi and orbi satellite but I can’t connect to xbox live and have the same problem you did and not sure what to do- twickenJun 06, 2019Aspirant
I was having issues with Xbox live as well as streaming Netflix and Amazon Prime through the Xbox one. Disabling Port Scan and DoS protection fixed the issue for me. Log into the router settings through http://www.routerlogin.net, then access Advanced->Setup->WAN Setup and check the box for "Disable Port Scan and DoS Protection".
