Mitewot
Aug 24, 2020Aspirant
Xbox killing network
Have seen some previous posts but no real solution. Frequently when I go to connect to Xbox live it will knock my Orbi network offline. Still getting internet to the modem, but nothing beyond that. I ...
Mstrbig
Aug 24, 2020Master
Mitewot wrote:
Have seen some previous posts but no real solution. Frequently when I go to connect to Xbox live it will knock my Orbi network offline. Still getting internet to the modem, but nothing beyond that. I have assigned static IP and put box in DMZ, but still not working. Any help would be appreciated.
Which model Xbox are you referring to. My Xbox 360 and Xbox One are not having any issues, I did not set up any ports, no DMZ, just forgot the WIFI networks and reconnected. Can get Xbox Live on both Xboxes. It probably has somethng to do with the static IP and DMZ. Try removing those settings, reboot the Orbi system, search for WIFI or connect cable, (which could also be the problem), on Xboxes and rejoin the WIFI network
- MitewotAug 24, 2020AspirantIt’s the XboxOne. The static IP and DMZ are my attempts to solve the problem based on some previous reads. The Xbox is direct connected to the router. Have experienced same issue wireless as well.
- MstrbigAug 24, 2020Master
Mitewot wrote:
It’s the XboxOne. The static IP and DMZ are my attempts to solve the problem based on some previous reads. The Xbox is direct connected to the router. Have experienced same issue wireless as well.One, try to reconnect either wired or wireless. I'm not sure why it's doing what it's doing.Any switches in between the Xbox and satellite or router?
- MitewotAug 24, 2020AspirantNegative. Hard wired to satellite. This is the only device that kills the network. I assigned a static IP of .200 to ensure there are no conflicts with any other devices.
