Mitewot
Aug 24, 2020Aspirant
Xbox killing network
Have seen some previous posts but no real solution. Frequently when I go to connect to Xbox live it will knock my Orbi network offline. Still getting internet to the modem, but nothing beyond that. I ...
Mstrbig
Aug 24, 2020Master
Mitewot wrote:
It’s the XboxOne. The static IP and DMZ are my attempts to solve the problem based on some previous reads. The Xbox is direct connected to the router. Have experienced same issue wireless as well.One, try to reconnect either wired or wireless. I'm not sure why it's doing what it's doing.Any switches in between the Xbox and satellite or router?
Mitewot
Negative. Hard wired to satellite. This is the only device that kills the network. I assigned a static IP of .200 to ensure there are no conflicts with any other devices.
- MstrbigAug 24, 2020Master
Have you tried plugging into the router instead of the satellite, to see if it acts the same way? I just searched the net and everything points to the XboxOne. IP conflict, bad cable, factory reset, power cycle, check network settings, etc.
