GadgetVirtuoso2
Jun 21, 2018Apprentice
XBox network transfer
One Xbox One is wired and the other is wireless. The wired on can transfer from the wireless Xbox, but the wireless Xbox can't even see the wired Xbox. Both are on the same network (no VLANs). The wi...
- Jun 21, 2018
I was able to resolve the issue by toggling the Network Transfer off and on both XBoxes. UPnP is turned off; this feature is only needed if you want the router to open ports to internal devices from the outside automatically and is not needed for any online gaming. It is still recommended by nearly all security professionals to turn off UPnP because of the security risks it presents.
Orbi like all consumer routers do not have a whitelist firewall, so it is not necessary to setup port forwarding or have UPnP enabled for these online services to work correctly. The default configuration is to pass all outbound traffic. You would have to actively block the XBox ports if you wanted to prevent this access.
GadgetVirtuoso2
UPnP should not be required for LAN services to work correctly. In fact, without UPNP I have had no issues with Xbox Live. I will try the alternate NAT port as you suggested, but I wouldn't expect that to matter since even both units use the same port it's on different IPs (or MAC address since it should just be L2 traffic).
DavidUnboxed
Jun 21, 2018Star
You are correct that UPnP would not come into play for a strictly LAN communication feature. However, I am not convinced (without a code review, and I no longer have access to MSFT source code since I don't work there anymore) that any LAN feature does also depend upon XBOX live features if not just to enable sharing or some other integration... If you think it is a LAN only issue, I would check to make sure guest isolation is not impacting the wireless client. If that bears no fruit, you may need to check the network connectivity for the wireless XBOX from a PC attached to see if it can communicate using PING and perhaps the XBOX App for Windows 10. Or substitute a PC with a static address on each end and run a more thorough test with network capture.
So far, I've not seen a single 1:many NAT and port forwarding implementation that could simultaneously forward the same external ports from the same range of remote hosts to multiple internal addresses. There may be some in the commercial device space intended to spread the load between incoming servers (if so, probably F5 devices, etc.) but that would certainly impact communication where devices expect 1 to 1 communication. https://en.wikipedia.org/wiki/Network_address_translation. Now, if you knew the exact XBOX Live server IP address each XBOX would talk to in advance, some NAT routers could set up a Port Forwarding rule separate for each. But, due to high availability design for XBOX live, it's not possible to predict the exact one that will be used in advance and thus UPnP is needed to ensure each can traverse the NAT, hit any of a group of XBOX servers, and where features require, get a response back through the NAT to correct LAN address. Perhaps XBOX live is working but in a limited manner such as Strict NAT? https://support.xbox.com/en-US/xbox-one/networking/network-settings. This is not the same as Open NAT and if the LAN feature does invoke any such calls to the XBOX live network they could be impeded.
