Matt1231
Sep 11, 2019Follower
Xbox one connection
The download speed on the Xbox is not steady. Goes from 300mbps-50mbps. I want to change it from being under the 5Gz to the 2.4Gz but I dont know how to. The internet around my house is great, its ju...
Sep 11, 2019Guru - Experienced User
xbox will connect to the best signal if feels. You can't make it go to 2.4Ghz. 2.Ghz is not recommended for gaming. WIred is preferred.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
