Lohrum
Dec 24, 2018Follower
Xbox One doppelte NAT; Orbi RBR50
Hallo, Ich habe folgendes Problem: In den Netzwerkeinstellungen meiner Xbox bekomme ich ständig nur den NAT-Typ "mittel" angezeigt mit der Begründung es gäbe eine "doppelte NAT". Ich habe jetzt ...
ekhalil
Dec 24, 2018Master
Lohrum wrote:
Hello,
I have the following problem: In the network settings of my Xbox I get constantly only the NAT type "medium" displayed on the grounds that there would be a "double NAT".
I have already seen in the English part of the forum that several people have this problem.
The Orbi router is connected to a Fritzbox 7490 and currently in router mode. The Xbox is upstairs and also connected via cable to an Orbi satellite. I have already tried the Orbi router in the Access Point mode to put, but throttled the Internet speed and on the Xbox appeared only more error messages (UPnP, Teredo).
Does anyone have similar problems with the Xbox or knows a solution to this problem?
Fritzbox 7490 is a wifi router. Since you have Orbi in Router Mode, Is the Fritzbox 7490 bridged and with wifi disabled?
