gsmitch13
Jun 26, 2019Aspirant
Xfinity App access no longer allowed?
My Orbi RBR50 is not allowing my Xfinity (comcast) apps to access internet from my wife and my iPhones and iPads. All other access for other apps and internet on them work fine only the Xfinity apps...
- Jul 02, 2019
Glad you got it working. Yes factory reset should include both RBR and RBS to be sure everything is cleared out.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
gsmitch13
Firm ware ver V2.3.1.60
Surfboard Model SB6190
NG support had me access advance settings and make changes to correct connection issues I was having with my Amazon, Nest and other devices. The tech suggested it was needed because of either an update or power outage may have caused settings to be error set.
All other internest apps on all four Apple devices work properly. ONLY the Xfinity apps fail to read the needed infromation from the wifi connection.
I bought the Orbi unit from Best Buy. I had never seen it before I entering the store as I was looking for an option to the Comcast equipment that was constantly dropping my camera feeds and many of my other numerous (now47) wifi connected devices. It worked perfectly for over a year. This issue became very apparent after a storm/power outage reset. First my Amazon equipment was a problem and during a support call with them the issue became more wide spread and they had me call NG support. It appeared everything was corrected and back to normal but the next day my wife complained she could not stream TV via the Xfinity app in checking I fould that none of my Apply devices could access their apps. I assumed (still do I think) that is was Xfiniry problem but their tech that showed up says it is the router. So I am dead in the water for a resoultion.
Jun 26, 2019Guru - Experienced User
What was it that NG support correctly to get your other apps running. Odd that they need to change something. I've never had to configure the Orbi for any app connections. All mine just work, though I don't have Xfininity. Seems that if you didn't make any changes other then what NG did and the XF app had been working and if you didn't change anything since, seems the app maybe a problem.
I presume you may have uninstalled this app and re-installed it? Does it happen with other devices as well?
Has a factory reset been performed and setup from scratch then tested again?
FYI about your ISP modem:
- gsmitch13Jun 27, 2019Aspirant
They had me check Advanced setting to check the 'ENABLE MU-MIMO, ENABLE FAST ROAMING, and on wireless setting change the 2.4 and 5.0 chanells to 9 and 44 respectfully.
Posible something else - not sure what.
Yes uninstalled and reinstalled to no avail. Still will not connect correctly.
I have found that if I access the hotspot on my phone with my iPad then use both Xfility apps they function correctly. As long as I so not close the apps and switch back to them Orbi they continue to function. If I close the app then reopen then they fail again.
- FURRYe38Jun 27, 2019Guru - Experienced User
Try this, input the IP address of your mobile device that has this app on it into the DMZ on the RBR. Save settings and reboot. Close the app on the mobile device. After the RBR is back to ready, try the app. Curious if this changes anything.
- gsmitch13Jul 02, 2019Aspirant
in checking the ORBI app both of the Apple iPhones and iPads are listed with the correct IP address. What do you mean by DMZ? This old Nam vet sees knows of only one meaning for it. ha!
