gsmitch13
Jun 26, 2019Aspirant
Xfinity App access no longer allowed?
My Orbi RBR50 is not allowing my Xfinity (comcast) apps to access internet from my wife and my iPhones and iPads. All other access for other apps and internet on them work fine only the Xfinity apps...
- Jul 02, 2019
Glad you got it working. Yes factory reset should include both RBR and RBS to be sure everything is cleared out.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
gsmitch13
Jul 02, 2019Aspirant
I did not fully do a reset of the ORBI RBR50 and the satilite - the reset was a normal one I had done before. I found on line the instructions to do it resetting both the router and satilite and reprograming the connections and passwords. Low and behold all is good. I for the life of me cannot understand why Netgear support did not say do this first!
All good now - thanks for your help and patience.
Jul 02, 2019Guru - Experienced User
Enjoy. :smileywink:
