zachMade
Oct 11, 2018Tutor
Xfinity Gateway as router, RBR50 in AP mode, two wireless RBS50 satellites
Hi,
I'm using an Xfinity Gateway that I originally set to Bridge mode so as to prevent double NAT, allowing the RBR50 to handle routing. I've since discovered that when reset or calling Xfinity...
- Oct 11, 2018
Yes, you can, use option #3. I listed the other options to let you know what other modes could be used.
Oct 11, 2018Guru - Experienced User
Yes you can.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Xfinitity also allows for BYOM as well...So you can get your own stand alone modem if you want the Orbi to be the main router.
- zachMadeOct 11, 2018Tutor
Hmm... that sounds more like a no I can't, in that it sounds like the RBR50 needs to be a router to mesh wirelessly with the two satellites.
- I previously had it set up this way, but if the Xfinity unit is going to revert to being a router every time I call Comcast (which is frustratingly frequently) I'll have to go in and fix the settings on the Comcast and Orbi all the time...
- I haven't tried this arrangement yet, but if Comcast will be reverting these settings frequently it likely brings me to the same issues as point #1
- The heart of my question: if I do this (disable Xfinity Wi-Fi, enable Xfinity router, set Orbi RBR50 as AP/not-router) will my two satellites (RBS50) still be able to mesh with the RBR50? (my assumption is no :smileysad:)
If I am unable to do the meshing as outlined in #3 I'm guessing my next best bet is a wireless extender instead of doing an all Orbi setup.
