PoorOldRudy
Aug 19, 2019Aspirant
Xfinity gigabit plan but Orbi maxes out around low 500Mbps
Just ditched the new Xfinity modem (the black technicolor one that looks like some kind of award/trophy) for an Arris SB8200. Before the Arris, my Orbi was consistently getting 400-450Mbps on the Orb...
Aug 19, 2019Guru - Experienced User
I've got an Orbi and can confirm it should work. I can regularly pull 940 mbps down on it through a CM1000.
did you try resetting after updating firmware and changing modems? Anytime you change modems, its a good idea to start fresh.
Are you using QoS?
- PoorOldRudyAug 19, 2019AspirantYes I factory reset the Orbi router and satellites after I got the new Arris modem up and running. On my Orbi admin I don’t have a QoS setting. But I don’t have or see any setting like that. I’ve heard some people mention that traffic meter is similar but I do not have that enabled either.
- plemansAug 19, 2019Guru - Experienced User
I'd start with replacing cables and trying a different device to see if that impacts it at all.
Are you hardwiring into a satellite or the main router?
I've had speedtest not max out my connection. have you tried testing through speedtest.xfinity.com or speedtest.googlefiber.net?
