PoorOldRudy
Aug 19, 2019Aspirant
Xfinity gigabit plan but Orbi maxes out around low 500Mbps
Just ditched the new Xfinity modem (the black technicolor one that looks like some kind of award/trophy) for an Arris SB8200. Before the Arris, my Orbi was consistently getting 400-450Mbps on the Orb...
PoorOldRudy
Yes I factory reset the Orbi router and satellites after I got the new Arris modem up and running. On my Orbi admin I don’t have a QoS setting. But I don’t have or see any setting like that. I’ve heard some people mention that traffic meter is similar but I do not have that enabled either.
Aug 19, 2019Guru - Experienced User
I'd start with replacing cables and trying a different device to see if that impacts it at all.
Are you hardwiring into a satellite or the main router?
- plemansAug 19, 2019Guru - Experienced User
I've had speedtest not max out my connection. have you tried testing through speedtest.xfinity.com or speedtest.googlefiber.net?
- PoorOldRudyAug 20, 2019Aspirant
As fas I I know you can only test the speeds for the Orbi router itself from the Orbi app and the admin from a browser. Both using speedtest.net.
Tried different cables. From Cat6 to Cat5e. It's not the speeds to devices I am worried about it's the speeds that the Orbi router is getting from the modem. The Orbi router is obviously hardwired into the Arris modem.
