lannyreese
Oct 08, 2020Aspirant
Xfinity modem with wifi routers
I need two different Wi-Fi routers in my home: one to run my Ring security system without interfering with my computer Wi-Fi network. I'm using the built in router in my Xfinity Modem for connecting ...
Oct 08, 2020Guru - Experienced User
its probably because they're both in router mode and causing a double nat. You can put the orbi in access point mode.
https://kb.netgear.com/30186/What-is-Double-NAT
- lannyreeseOct 08, 2020Aspirant
Thank you very much, I'll try immediately.
