jessepoteet
Apr 12, 2021Aspirant
Xfinity oauth.xfinity.com blocked for no reason
I had this issue last year when I did the trial of the Netgear Armor security feature. Armor turned out to be a disaster and screwed up the system and was blocking oauth.xfinity.com from loading, so ...
Apr 13, 2021Guru - Experienced User
What modem do you have?
what firmware is on the orbi?
jessepoteet
Apr 13, 2021Aspirant
Firmware for router and satellite is V2.6.2.104
Modem is a Netgear AC1600, Model C6250.
- plemansApr 13, 2021Guru - Experienced User
does the C6250 has its router mode disabled?
or is the orbi in access point mode?
otherwise it can be in a doulbe nat.
How to fix issues with Double NAT | Answer | NETGEAR Support
- CrimpOnApr 13, 2021Guru - Experienced User
I do not see this as a Double NAT issue. It worked for months and months, and then one day it no longer works.
Internet searches turn up plenty of questions about "Why can't I access Xfinity?" that are not related to Orbi.
There was one that claimed oauth.xfinity.com resolved to three separate IP addresses and one of them was not responding. If that IP address was cached by the Orbi or the ISP router, it might appear "dead".
Has everything been rebooted? (Mac, Orbi ISP modem?) Not "reset", just powered off and on again?
- jessepoteetApr 13, 2021Aspirant
The modem's router is disabled and routing is handled by the Orbi.
Yes, all have been unplugged for several minutes and then plugged back in. Issue still remains.
