stevedavis
Oct 01, 2020Aspirant
Xfinity router to bridge mode and Orbi RBK50 to AP mode
So I have everything set up and running really well but I read that AP mode is the way to go. Tried it and it didn't work. What I've read or seen videos of was either setting up the router or the O...
- Oct 01, 2020
I wouldn't change things if you are satisfied with how things are running. Using your Orbi in the default Router mode leverages all of its functionality. If you must switch it to AP mode, follow the instructions at: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Before switching your Orbi to AP mode, make sure your Xfinity gateway is not in bridge mode. By default the Xfinity gateway is not in bridge mode so you shouldn't have a problem unless you or someone else modified it. You still need something to operate as a router and putting your Orbi into AP mode removes its router functionality.
Mikey94025
Oct 01, 2020Hero
- stevedavisOct 03, 2020Aspirant
Having the ISP router in bridge mode was my problem when first putting the Orbi in AP mode. Set it up last night just to see if I could do it right and it worked like a charm. Will just leave it in AP mode now as I'm done messing with it. Ran a speed test in the same room and it was 530/17 and at the end of the house where the speeds were always the worst it was 450/15. After the firmware update, the satellite went from connecting to two devices at the far end of the house to another handful that are in close proximity.
Thanks for your help and suggestions.
