MikeRBR50V2
Jun 08, 2021Aspirant
Yes another RBR50V2 dropping connection
I have a RBR50V2 with firmware V2.7.2.104 connected to Optimum internet Arris Modem Touchstone CM8200. Warranty swapped my router with NETGEAR & warranty swapped the modem with the ISP. Tried the teln...
Jun 08, 2021Guru - Experienced User
You mean this?
Be sure your running a telnet session wtih Admin rights enabled?
Check your telnet app mfr for help and support for there app.
MikeRBR50V2
Jun 09, 2021Aspirant
Thank you. I enabled telnet in the router debug login and setup telnet on my windows 10 laptop as admin but none of those commands work in telnet. Am I missing something? Thank you again
- FURRYe38Jun 09, 2021Guru - Experienced User
What telnet app are you using?
Putty or Terra term?
- MikeRBR50V2Jun 09, 2021AspirantI’m using the cmd prompt inside of windows 10
Try Terra Term or Putty and see.
