rbmattis
Mar 19, 2021Tutor
Yet Another RBR50 Dropping Internet Connection
Hi, apparently, I'm not the only one with RBR50 issues. I recently moved and updated my RBR50 to v2.7.2.104 firmware. I also have two RBS50 satellites running the same firmware. My issue is...
CrimpOn
Mar 19, 2021Guru - Experienced User
The most common advice is to either:
- Perform a Factory Reset and clean configuration on the router, or
- Manually install the previous firmware.
It is a mystery why this happens to some Orbi's when updated to 2.7.2.104 and not to others. It may be related to the specific ISP. (I am also on Spectrum, and do not have this problem. However, my Spectrum franchise was originally Comcast, which got bought by Adelphia, which got bought by Time Warner, which is not Spectrum. Who knows how the "parts" in MY Spectrum cable system compare to the electronics in other franchises.)
