rbmattis
Mar 19, 2021Tutor
Yet Another RBR50 Dropping Internet Connection
Hi, apparently, I'm not the only one with RBR50 issues. I recently moved and updated my RBR50 to v2.7.2.104 firmware. I also have two RBS50 satellites running the same firmware. My issue is...
chrisg331
Mar 19, 2021Initiate
Under NTP Settings, I changed the following:
Uncheck
Automatically adjust for daylight savings time
Check
Set your preferred NTP server
and change NTP server to: time.nist.gov
Save and reboot. This is on V2.7.2.104. This has worked for me for the last 48 hours.
I tried the factory reset and the older FW versions all the way back to RBR50-V2.7.0.70 without any luck.
Good luck.
- spewakMar 19, 2021Luminary
I'm going on 5 full days sans lost connection using this method.
