rbmattis
Mar 19, 2021Tutor
Yet Another RBR50 Dropping Internet Connection
Hi, apparently, I'm not the only one with RBR50 issues. I recently moved and updated my RBR50 to v2.7.2.104 firmware. I also have two RBS50 satellites running the same firmware. My issue is...
vajim
Mar 22, 2021Master
rbmattis wrote:Hi, apparently, I'm not the only one with RBR50 issues.
My issue is that about once a day, my RBR50 loses its internet connection. The RBR50 is directly connected to a Arris cable modem and Spectrum. The cable modem is not having connection issues. I can plug something else into the cable modem and it works fine. The solution for the problem is rebooting the RBR50. Like others, I'm at wits's end. I changed the wan_lease=1200 but I don't know whether or not that will change anything. I don't have Armor or Circle.
Any other tips? thanks!
tips?
roll your firmware back if possible.
