rbmattis
Mar 19, 2021Tutor
Yet Another RBR50 Dropping Internet Connection
Hi, apparently, I'm not the only one with RBR50 issues. I recently moved and updated my RBR50 to v2.7.2.104 firmware. I also have two RBS50 satellites running the same firmware. My issue is...
Tribikn3112
Mar 22, 2021Aspirant
I have the exact same RBR50 system with satellites.Had same problems after v.104 update. Even got locked out of being able to login to the router with ethernet cable. Had to do a password recovery using the router serial number, answer security questionss where I had to leave blank for the answers. I manually rolled back to V2.6.1.40 on all devices, and problems have not gone away, completely. Issh......
