realien
Jan 16, 2023Tutor
You are currently logged in from another device. There can be only one device logged in at a time. I
I am on a mac book pro. I am using an Orbi RBK50 (I have two satellites too). I keep getting this message when logging into the web-based admin interface. Sometimes I can get to a menu (e.g., spe...
- Jan 16, 2023
Yes, the Orbi web server allows connection from only one IP address. When it detects a connection attempt from a different IP address, this warning pops up. There can be simultaneous connections from different browsers as long as they are on the same computer. (I just did it as a test.)
How is this Mac connected to the router (wired or WiFi)?
(Recent software updates created all sorts of confusion when the default became to randomize the MAC address when connecting to WiFi rather than use the actual hardware MAC address.)
CrimpOn
Jan 16, 2023Guru - Experienced User
realien
Jan 18, 2023Tutor
So I think you led me to the solution. My mac is using both ethernet hardware and wifi, the service order is set to use hardwire first. However, it looks like the mac can jump between the two, since the performance is quite close (maybe a 100 Mbit difference at 900 Mbit)...
I disabled the wifi and connected to the web admin interface on hardwire ethernet only and have not had the issue since.
thank you.
