Trikon
Nov 09, 2023Aspirant
Your connection is not private after using router admin
I am running RBR50 with connected RBS50 both running the same firmware V2.7.4.24. The firmware version is irrelevant since this problem has dogged me since getting the routers. The issue After...
michaelkenward
Nov 09, 2023Guru - Experienced User
microchip8 wrote:
You don't mention which browser you use.
Good point.
Trikon mentions using a Macbook. Macs can mean Safari.
I forget to mention this in my reply. It adds another layer of complexity. Some Netgear manuals specifically warn that Safari can't be used for some functions, such as Password Recovery.
That warning isn't there for newer devices. So either Safari has changed or Netgear has worked out how to handle the issue.
But, as you say, Trikon's beef nothing to do with the router.
Trikon
I dont use Safari, I use Chrome.
