Trikon
Nov 09, 2023Aspirant
Your connection is not private after using router admin
I am running RBR50 with connected RBS50 both running the same firmware V2.7.4.24. The firmware version is irrelevant since this problem has dogged me since getting the routers. The issue After...
Trikon
"From time to time, someone turns up here screaming about their "broken" router when what they have done is told it to Always Use HTTPS to Access Router. Doing this blocks various things so they usually go back and this turn off.
I loathe this product and right now would never recommend it.
If you reached that conclusion on the basis of that misleading error message, I fear that you may have to abandon the Internet. What you are describing is a "feature" of modern browsers and routers."
For you informaiton, I find these remarks vaguely condescending and rather dismissive - not really what I was expecting in a help forum. For your information, I have been working in IT since 1985 and have been an internet user since 1994. I think I can consider myself quite good at problem diagnosis, I may be a software expert but not a networking expert.
This problem only occurs immediately after logging on to the router https://10.0.0.1 to add new devices to the network via access control. It does not occur at any other time. I use the latest version of Chrome. It seems to be a wifi issue because when I connect via wired, I get access fine.
michaelkenward
Nov 09, 2023Guru - Experienced User
How many routers do you have on your network?
What is the modem/gateway/ONT that connects you to the Internet.
I ask because by default Netgear's routers allocate themselves the address 192.168.1.1. They will only go for 10.0.0.1 if they spot a possible conflict. That can happen when someone tries to add a router to a modem/router.
Do that and you can end up; with all manner of problems.
All of a sudden we have a different issue, and a different set of details.Again, the problem, appears to be in your network rather than the router.
What is it that you really want to fix?
In general, the advice from experienced users is to do as much as possible with a wired connection. Wifi is not reliable enough.
- TrikonNov 09, 2023Aspirant
Q. What is the modem/gateway/ONT that connects you to the Internet?
A. I have full fibre to the property - some kind of fibre to Ethernet modem that I plug into the base router. NOthing there has changed.
A. My network is setup to use 10.0.0.xxx, I cant remember why. I have Access Control nailed down with registered MAC addresses for each known device. I always access the router using the 10.0.0.1 address.
I have one base router and one satellite router in operation presently. My second satellite I am not using currently. Because the satellite is in my office, I would generally use this when accessing the router admin.
Interesting, I tried the 192.16.1.1. address and then my device disconnected from the network - quite bizarre.
A. Barring the physics of wireless communication, surely the network is the router?
A. I dont want my laptop locked out of the network and internet access everytime I finsh doing router admin the add ot remove devices in the access control function. I really dont think this is unreasonable.
A. This seems like good advice. Perhaps I should also access the base router not a satellite router.
- michaelkenwardNov 09, 2023Guru - Experienced User
We still know nothing about the equipment that delivers the Internet to your home.
"Some kind of" is not much help.
Not sure what "nothing has changed" is meant to tell us. The network attached to it has changed, if only when you play around with things. That is how the local IP address gets allocated.
A. My network is setup to use 10.0.0.xxx, I cant remember why. I have Access Control nailed down with registered MAC addresses for each known device. I always access the router using the 10.0.0.1 address.I have one base router and one satellite router in operation presently. My second satellite I am not using currently. Because the satellite is in my office, I would generally use this when accessing the router admin.
Two routers on a network is a recipe for chaos.
For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit. - michaelkenwardNov 09, 2023Guru - Experienced User
Yet another previously undisclosed detail.
Anything else you haven't thought of telling us before?
