Trikon
Nov 09, 2023Aspirant
Your connection is not private after using router admin
I am running RBR50 with connected RBS50 both running the same firmware V2.7.4.24. The firmware version is irrelevant since this problem has dogged me since getting the routers. The issue After...
Trikon
"I don't know how you arrived at the conclusion that this is not the problem. How did you work that out?"
The problem occurs if I enter https URLs directs, I am not trying to access HTTP addresses.
michaelkenward
Nov 09, 2023Guru - Experienced User
That does not suddenly turn an http link into https.
- microchip8Nov 09, 2023MasterDo you trust your own network? If so, there's no reason to use HTTPS. Also, using HTTPS will still throw a warning as the certificates are self-signed and not part of the browser to recognize them.
