Trikon
Nov 09, 2023Aspirant
Your connection is not private after using router admin
I am running RBR50 with connected RBS50 both running the same firmware V2.7.4.24. The firmware version is irrelevant since this problem has dogged me since getting the routers. The issue After...
Trikon
Really?
"Two routers on a network is a recipe for chaos?"
Two ORBI Routers - A Base router and a satellite router - it's a mesh network.
michaelkenward
Nov 09, 2023Guru - Experienced User
No it isn't. Mesh means satellites and routers talking to one another to manage wifi links. That communication won't work between two routers.
Maybe you have two mesh networks with the same SSID. That's not the same thing as one mesh network.
Two routers = trouble.
Regardless of their brand and claimed wifi features.
If these routers are the same model, then you best bet would be to remove one of them and stick with the satellites.
As it is, your two routers will find it impossible to coexist with the same local IP address. Perhaps that is why you have one that is not on the default 192.168.1.1. (I assume that you just made a mistake when you referred to 192.16.1.1.)
