esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Oct 08, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well. This is for wireless connected satellites only and problems seen with them.
ekhalil
Oct 08, 2018Master
Daisy Chain is enabled in my case, and I can see this by seeing that there are 2 hidden 5 GHz backhaul networks (one from each node, in my case one from the router and one from the satellite). I tried disabling Daisy Chain (in this case you will only see one hidden 5 GHz backhaul network from the router) but that did not help. Anyway, I have wired backhaul and only one Satellite so Daisy Chain should not have any role here :)
FURRYe38 wrote:If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
