esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
dkleinknecht
Oct 30, 2018Star
Anyone else having issues with the VPN implementation? I have to keep disabling then re-enabling it to work. When it's "not working" I can still login to the VPN and access devices on my home network, but I can't connect to anything outside of it. I have the VPN set to "All sites on the Internet & Home Network" and when I enable the VPN server it will work for a few minutes, but then out of what seems like nowhere will kill the connection to the internet and give me only access to the home network. If I disable and re-enable the VPN then it works again for a bit.
Didn't have this problem before 2.2.1.210.
Also REALLY frustrating that the update was forced AGAIN. With this VPN issue and the fact that Netgear keeps forcing these updates, I'm really considering going back to my Amplifi system.
MikeTheActuary
Nov 03, 2018Tutor
When I first started using Orbi's VPN, I found that I had to check "all sites on the internet and home network" option AND re-download/re-apply the applicable OpenVPN config file to get it to work properly.
I also found that I had to enable guest network AND make the regular network visible to the guest network in order to access machines at home through the VPN.
- dkleinknechtNov 04, 2018Star
I've tried all of this, I've even changed the ports and re-enabled VPN then downloaded the new profiles to use, same problem.
This only started happening after the latest forced updated, was fine on the previous version. It's really frustrating.
- FURRYe38Nov 05, 2018Guru - Experienced User
You might want to contact NG support about this...
- dkleinknechtNov 06, 2018Star
Probably, but I'm well outside of my 90 day "complimentary" support period, and I'm not paying them to fix their own issues. It's pretty clear there are a lot of people who are upset over these forced updates, and Netgear is doing nothing about it, never mind the people who are having issues because of these updates.
