esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Nov 05, 2018Guru - Experienced User
You might want to contact NG support about this...
dkleinknecht wrote:
I've tried all of this, I've even changed the ports and re-enabled VPN then downloaded the new profiles to use, same problem.
This only started happening after the latest forced updated, was fine on the previous version. It's really frustrating.
dkleinknecht
Nov 07, 2018Star
Probably, but I'm well outside of my 90 day "complimentary" support period, and I'm not paying them to fix their own issues. It's pretty clear there are a lot of people who are upset over these forced updates, and Netgear is doing nothing about it, never mind the people who are having issues because of these updates.
- LycanChiefNov 07, 2018Star
Guys, v.210 is bad firmware....This is sad that Netgear have not pull the firmware out yet. I fix my issue downgrading to v2.1.4.16 and disable Auto-Update for the time been.
Fallow my post at:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1661264#M44976
- FURRYe38Nov 07, 2018Guru - Experienced User
You should make contact anyways, Possible issue with your hardware. This has happended as well. NG might replace it. It would be worth an RMA if you've never done an RMA. Try to find out.
- OrbiNov 08, 2018Star
I agree, version 2.2.1.210 is bad. I've had constant slow downs and drop outs with this firmware than any other. Everyday its like having a dialup connection with this router, now.
- dkleinknechtNov 09, 2018Star
Thanks, I’ll give it a shot.
- FURRYe38Nov 09, 2018Guru - Experienced User
