esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Jan 03, 2019Guru - Experienced User
Do a full reboot of the ISP Modem, Orbi router and satellites.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings
georgengan wrote:
I'm in the UK. My configuration: RBR50 + RBS50 + RBS40 with. No change in placement for 13 months. RBR50 is in the basement. The RBS50 is two floors above the router and the RBS40 is one floor above the router. Before the auto update of 2.2.1.210 (therefore I am not sure about the exact date of the FW update), the RBS50 is daisy chained to RBS40, and RBS40 is connected to RBR50. All wirelessly connected.
(1) Around/right after the auto FW update, there were increasing occurances of droping wifi signal (iMac wifi signal icon shows disconnection for a sec or two and then re-connected). I'm ok with it becuase I rarely stream.
(2) About two weeks ago, connection speed slowed down by half (from 55+ Mbps to 25+MBps), we have many imacs/ipads at home, and most of the connections change from 5G to 2.4G. I performed the normal power-down/power-up and resync. Most of the iMac still connect at 2.4G with reduced download speed. I can live with that.
(3) I havn't checked the Router page for a while and I check it today. Two strange things happened: the satellites are no longer daisy chained but all connected to the router; the backhaul status show poor connection. The imacs are still connected at 5G for those attached to the RBS50, but those devices connected to the RBS40 shows 2.4G. Download speed is only 25+ for those at 2.4G.
(4) I poweroff/on all three orbis, all backhaul status are still "poor" after one hour and the two satellites are still connected to the router (it takes sometime for the orbi to "sink-in" the config as far as I understand). I finally found this thread and change the 2.4g channel to 11. Now, the backhaul status of the RBS50 is still poor (naturally because it's tow floors above the router) while the RBS40 is showing "good". HOWEVER, when I run broadband speed test on all computers and devices, the speed are now back to 55+ Mbps.
The strangest thing is about daisy chain, it makes no sense for the RBS50 connecting to the router because it is definitely further away from the router than to the RBS40!
Just FYI.
teddyp12
Jan 30, 2019Initiate
Ever since the update initialized, my orbi router appears to be cycling every few seconds causing havoc on my security system and business computers using USB WIFI adapters. If have attached my event logs since the automatic update in hopes that someone can make a recommendation.
It was completely stable before the initialization.
[UPnP set event: del_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:52:21
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:52:16
[UPnP set event: del_nat_rule] from source 192.168.1.7, Tuesday, January 29, 2019 17:50:54
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:50:51
[UPnP set event: del_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:50:46
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:46:28
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:22:50
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:58
[Time synchronized with NTP server] Tuesday, January 29, 2019 16:19:53
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:42
[admin login] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:36
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:03
[Internet connected] IP address: xx.xx.xx.xxx, Tuesday, January 29, 2019 16:18:45
[Initialized, firmware version: V2.2.1.210] Tuesday, January 29, 2019 16:18:44
- JoeCymruJan 30, 2019Virtuoso
UPnP is more for a home system, and even then it is a potential security issue. Personally I would never use UPnP in a business atmosphere. Actually I always check at updates to make sure it is disabled.
Devices on your system are constantly trying to open / close firewall ports and / or are sending requests to reconfigure themselves for whatever reason. Maybe gaming? But in general, not good. If you need specific connections use port forwarding so you can be selective and a lot more secure. More of a hassle but for the sake of security it is worth it.
- teddyp12Jan 30, 2019Initiate
Thanks for the advice, It has corrected my issue. I removed the UPnP access and went back to wireless WPA2-PSK access.
I also disabled and enabled my firewall to give my security system access.
