rollinsj
Jul 03, 2017Initiate
Z-Wave Integration - Orbi Wifi System
 Reference using Z-Wave with Orbi Systems.  Went to the Netgear Support and they said post the question here.  So, does anyone know if Netgear will eventually be able to link Z-wave devices with the O...
rollinsj
I have several items (locks and doorbells) operating on Z-wave and just wanted to know if they will eventually be picked up with the Orbi. There are some products that have it planned to allow full access.
loomis1975
Jul 05, 2017Luminary
If you want mesh wifi and home automation in the same unit, the only mesh router I know of is the Samsung Connect Home system, it has a Smartthings hub built in, and all that goes with that.
