Dranik
Jun 24, 2020Initiate
Zero handoff RBR50 doesn't seem to be working right
Hello,
I have Orbi RBR50 and one satellite. When I'm moving from my house to a backyard zero hand off is not working and it takes a maybe 5 seconds to get connected from the router to satellite. I see that wifi gets disconnected and then connected again. If I'm on a call then call get dropped as well. My phone is Samsung S10 plus, so it should be compatible. Sattelite connected to the main using using wire.
Running the same firmware on router and satellite V2.5.1.16. I don't think it ever worked properly.
These all are enabled.
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices |
| Enable MU-MIMO |
| Enable Fast Roaming |
If someone has any idea how to make zero handoff to be close to zero without dropping a call please let me know.
1 Reply
handling of the switching of the signals is also a mobile device handling event as well, it's up to the device to make this switch when signals and conditions change. Something to ask Samsung about.
Wifi signal over lap is important between the RBR and RBS.
