JW_Wimpy
Apr 13, 2017Guide
...another LB1120 question.
Just purchased the LB1120, but haven't received it yet. I assume it doesn't include a SIM card, but does it have an IMEI number? Tried to sign up with Cricket (owned by AT&T) online and they ins...
- Apr 13, 2017
The LB1120 IMEI will be printed on the label on bottom of unit.
Steve
egaviria
Jun 04, 2017Aspirant
Does anyone know how many wireless devices can I connect to this LTE modem?
- DarrenMJun 08, 2017Sr. NETGEAR Moderator
LB1120 has 1 Ethernet port on back of it so only one device can be connected directly to it however the device has two modes of operation bridge and router mode in router mode (default operation mode) you can connect a 8 port, 16 port, 24 port switch or a router which will allow you to connect lot more devices.
DarrenM
