JW_Wimpy
Apr 13, 2017Guide
...another LB1120 question.
Just purchased the LB1120, but haven't received it yet. I assume it doesn't include a SIM card, but does it have an IMEI number? Tried to sign up with Cricket (owned by AT&T) online and they ins...
- Apr 13, 2017
The LB1120 IMEI will be printed on the label on bottom of unit.
Steve
egaviria
Jun 14, 2017Aspirant
Thanks.
Now I have another problem. After a while, device turns off celullar data by itself. It is currently set in router mode connected to an Apple Time Capsule. How can it set it up in order that the internet in never disconnected?
DarrenM
Jun 16, 2017Sr. NETGEAR Moderator
Hello egaviria
You may want to check page 55 of the manual make sure the setting to shut off after using so much data is not on.
http://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf
DarrenM
