JW_Wimpy
Apr 13, 2017Guide
...another LB1120 question.
Just purchased the LB1120, but haven't received it yet. I assume it doesn't include a SIM card, but does it have an IMEI number? Tried to sign up with Cricket (owned by AT&T) online and they ins...
- Apr 13, 2017
The LB1120 IMEI will be printed on the label on bottom of unit.
Steve
vronp
Jul 11, 2017Guide
Any luck on the antenna front? So far, the best looking antenna I've found is a Panaroma brand but it is pricey at around $150 and the gain at 700Mhz is only 2dbi.
All the stuff on Amazon seems to be garbage....
JW_Wimpy
Jul 12, 2017Guide
I had forgotten that people don't write things up anymore, they make videos. Turns out YouTube was a good source of info on external antennas. The paddle antenna is working adequately for now, I'll look into doing an attic mounted yagi in the fall when it isn't 130degF in my attic.
