robatl
Sep 06, 2021Star
> Remote Management
Nighthawk LAX20 Firmware Version V1.1.6.28_2.0.49 Remote management missing from the router configuration. Is this not a feature?
- Sep 07, 2021
The Anywhere access in the app is only for allowing the app to access the router from anywhere. That does not enable the router to accecpt http nor https requests.
Blanca_O
Sep 07, 2021NETGEAR Employee Retired
Hi robatl
Welcome to NETGEAR Community!
We've verified this with the product team and they have confirmed that there is no option to enable/disable remote management from the router UI. You can use the Nighthawk app to enable/disable Anywhere access.
We already requested the team to update LAX20 User Manual.
Blanca
Community Team
robatl
Sep 07, 2021Star
