drego85
Jun 04, 2023Guide
[2023] Latest Firmware Update for Netgear M2 - MR2100
Hello,
I own a Netgear MR2100-100EUS which has not received firmware updates for thre years now.
Versione hardware: 1.0
Versione firmware: NTGX24_10.17.08.00
Versione del modem: SDX24_10.25.00.06
Versione GUI: MR2100-100EUS_04.02.171.00
Versione PRI: 05.04
Data build firmware: 2020/08/21
But I find, even on this forum, different information that the latest firmware should be 10.19.x.x.
I have tried updating the firmware via 4G network, via Off-Load Ethernet but the router keeps telling me that there are no updates or it crashes the check.
Can you kindly tell me what is the latest firmware version?
Thanks
Andrea
- drego85Guide
Hi,
can any one tell me what is the latest firmware version for MR2100-100EUS? - BlueMistAspirant
I bought MR2100 in 2022 and not a single firmware update yet from Netgear. Either they think the product is superior or doesn't require any further improvements and bug fixes...
- JohnPengNETGEAR Expert
Could you please capture a model.json file and send email to me at jopeng@netgear.com with your community ID for easy reference.
Thanks
