B_S
May 30, 2016Aspirant
330U firmware needed
I accidently installed the 313U firmware onto my 330U (dumb mistake). Now Windows 7 does not recognize the aircard when it is plugged in. Please help!
netwrks
May 30, 2016Master
Have you tried installing the correct version?
- B_SMay 30, 2016Aspirant
I cannot find the 330U firmware anywhere.
This is the firmware I need: SWI9200X_03.00.08.03AP
- DarrenMMay 31, 2016Sr. NETGEAR Moderator
Hello B_s
Have you tried to install the aircard watcher you can find it in the downloads of the support of the 330u page.
http://www.netgear.com/support/product/AirCard_330U_(Rogers).aspx?cid=gwmng
DarrenM
- B_SJun 01, 2016Aspirant
Yes, I was able to install the watcher, but it does not recognize that the stick is installed. The watcher installation does not update the firmware.
