B_S
May 30, 2016Aspirant
330U firmware needed
I accidently installed the 313U firmware onto my 330U (dumb mistake). Now Windows 7 does not recognize the aircard when it is plugged in. Please help!
netwrks
May 30, 2016Master
Have you tried installing the correct version?
B_S
I cannot find the 330U firmware anywhere.
This is the firmware I need: SWI9200X_03.00.08.03AP
- DarrenMMay 31, 2016Sr. NETGEAR Moderator
Hello B_s
Have you tried to install the aircard watcher you can find it in the downloads of the support of the 330u page.
http://www.netgear.com/support/product/AirCard_330U_(Rogers).aspx?cid=gwmng
DarrenM
- B_SJun 01, 2016Aspirant
Yes, I was able to install the watcher, but it does not recognize that the stick is installed. The watcher installation does not update the firmware.
- DarrenMJun 01, 2016Sr. NETGEAR Moderator
B_S
Do you happen to have any other software from your ISP installed on the PC? If so try to remove it and see if the PC see the the card.
DarrenM
