rramse's avatar
rramse
341U max operating temperature
I wanted to permanently mount it on my roof using a USB repeater cable, but it's going to be 120 degrees F all week here in Phoenix.
What is the maximum ambient air temperature that this can safely stay activated?
The Franklin U770 spec says max operating temp 60 degrees C = 140 F.  (Could be bogus.)  Is there a Netgear aircard that can run this hot?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rramse
    I will have to check on this but I wouldn't recommend doing that as it was not built to withstand the elements.
    DarrenM
