HJTeix
Oct 18, 2021Guide
403 forbidden error !!
I and many people need a new firmware to fix the 403 forbidden error problem!! The new 1.0.0.52 not solve the problem and disconnecting the cable not works anymore! In 1.0.0.48 it still works but ...
- Oct 19, 2021
I doubt if many of those people hang out here.
HJTeix wrote:
Model: R6080|AC1000 Dual Band WiFi RouterThat is a basic Netgear router, not one of the "Mobile Routers, Hotspots & Modems" covered in this section. They have little in common with your hardware.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
Oct 18, 2021Guru - Experienced User
1. what modem/gateway are you connected to?
2. when are you getting the error?
3. have you enabled ipv6?
HJTeix
Oct 18, 2021Guide
Modem Zoom model 5345.
After I switched to the new firmware. I went back to the old and as I wrote, there is another bug and going back to the new one was the same. I tested 3 firmware and each one has a different bug. I'm not a stupid guy and I know what I'm doing. Netgear is bad with programmers and several routers have bugs. The problem is that they don't try to solve problems fast or they don't.
