HJTeix's avatar
HJTeix
Guide
Oct 18, 2021
403 forbidden error !!
I and many people need a new firmware to fix the 403 forbidden error problem!! The new 1.0.0.52 not solve the problem and disconnecting the cable not works anymore! In 1.0.0.48 it still works but ...
  • michaelkenward's avatar
    Oct 19, 2021
    I doubt if many of those people hang out here.
    HJTeix wrote:
    Model: R6080|AC1000 Dual Band WiFi Router
    That is a basic Netgear router, not one of the "Mobile Routers, Hotspots & Modems" covered in this section. They have little in common with your hardware.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
