HJTeix
Oct 18, 2021Guide
403 forbidden error !!
I and many people need a new firmware to fix the 403 forbidden error problem!! The new 1.0.0.52 not solve the problem and disconnecting the cable not works anymore! In 1.0.0.48 it still works but ...
- Oct 19, 2021
I doubt if many of those people hang out here.
HJTeix wrote:
Model: R6080|AC1000 Dual Band WiFi RouterThat is a basic Netgear router, not one of the "Mobile Routers, Hotspots & Modems" covered in this section. They have little in common with your hardware.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
HJTeix
Oct 22, 2021Guide
Test an r6080 with firmware 1.0.0.52 and stop writing non nosense!
Ther are others who have written about this problem and if you look it up find it.
michaelkenward
Oct 22, 2021Guru - Experienced User
That is your second "no sense" message in a row in this section.
I step in just to repeat that I doubt if anyone in this section – for Mobile Routers, Hotspots & Modems – knows much about the R6080.
The people here own a pretty fancy bit of network hardware rather than the cheapest and what must be the least capable router that Netgear currently supports. (I am surprised that, in 2017, when the R6080 first appeared, anyone put out a router limited to "Four RJ-45 ports supporting 10/100BASE-T", a seriously old Ethernet standard.)
If you want sensible answers, you might like to duck out of this place and carry on your conversations in the right section.
