MFK2020
Sep 15, 2021Aspirant
4G connection
Good day all,
Here is my issue with my rooter , it wont connect to 4G ( I have full signal on my location) but 3G+ it does.
When I set only 4G it says the data broadband is disabled
What I did :
1- Reset with and without battery
2- Disable Wifi and thethring stan by
3- Checked several times the APN
4- Tried te sim on another rooter , 4G working fine
5- Tried another sim card in my rooter still the same problem coonectng only on 3G
If some one can help that will be really great
1 Reply
- MFK2020Aspirant
Hello all,
The modem was band locked by the network provider ...
