guyvaknin's avatar
guyvaknin
Follower
Aug 21, 2020
4G hot spot portable
Hi All,
i'm searching for 4G router that can works outdoor.
the 4G router should power on for 2 hours for 30 days withoout electricty.
i will appricate any solution thay you familer with.
thanks in advance,
Guy
No RepliesBe the first to reply
