Juxone
Jul 09, 2021Follower
4G LTE Broadband Router that works with Verizon Sim (US)
Hi, I currently have a Verizon MiFi Hotspot but because it goes offline frequently and does not automatic power back on, ally I am looking for a Netgear broadband Router that someon KNOWS will work ...
GSBJackson
Jul 24, 2021Aspirant
I was able to get the LM1200 added to my VZW plan as a hot spot under the $20/mo unlimited option. I recommend purchasing the device, DO NOT OPEN, enter the IMEI into your add device on the website. VZW should recognize and confirm compatibility. If so, you can swap your SIM card and you should be up and running in 5-10 mins.
I have noticed that as VZW continues to rollout 5G, that 4g only devices are getting throttled back. When I set my iPhone 12 to 4g only data I get speeds of only ~20mg, on the LM1200 I get between 4 - 10mg max... just so you know.
- GSBJacksonJul 24, 2021Aspirant
As for WiFi, the LM1200 is designed to be a "wired" device much like a cable modem. You must use the LAN port to rj45 plug directly into a WiFi router (WAN) or your laptop/PC.
