MRHommel1's avatar
MRHommel1
Initiate
Feb 04, 2017
4G LTE Modem LB1120 Questions
With this series of modems that are being released, will they already have the sim card in them for AT&T? Will I be able to purchase the optional antennas' when it is released as well?
Also, will they work just like a regular cable modem hookup via ethernet would?  ie: Am I able to turn off the firewall or NAT or DHCP and connect it directly to my R7000 WAN port.
There is no internet other than satellite available at the home we moved into and Verizon Wireless has terrible service.  AT&T has great service out here and I would like to switch to them.  My plan is to hook this device up to my current home network with a 50GB plan and use it as a regular, full time modem.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello MrHommel1
    You will have to check with ATT if it is sold with a sim card or not and no antennas. And yes you can plug this into a router.
    DarrenM
  • To Netgear: This is an excellent device. Please try and get Verizon to recognize these devices as valid for activation; they work fine with Verizon SIM cards, but can't be directly registered.
