Shoguy479's avatar
Shoguy479
Follower
Mar 02, 2017
4G LTE Modem LB1120
I am wondering if this will work with a verizon sim card? The LB1120.
  • No, the LB1120 will not work with a Verizon SIM card (or a Sprint SIM card).
    The LB1120 will work with ATT or TMO SIM cards in US or with Rogers, Bell or Telus SIM cards in Canada.
    Steve
  • stevesw's avatar
    stevesw
    NETGEAR Expert
    Steve
    • ac2's avatar
      ac2
      Has the LB1120 been tested with Freedom Mobile (Formally Wind Mobile - another Canadian Provider), or perhaps even Fido?
      From my discussions with Freedom Mobile tech support, their Sim cards are comptatiable with any device that operates on 1700/2100 band.
      Alex
      • stevesw's avatar
        stevesw
        NETGEAR Expert
        I am not aware of any specific testing done on Freedom Mobile.
        However, the LB1120-100NAS does support LTE Band4 (1700/2100) so should be compatible.
        Fido is an MVNO on the Rogers network, so should also work.
        Steve
  • Worked fine with 2 different Verizon SIM cards swapped from. Phones, but Verizon would not recognize the IMEI on the device. I simply left the SIM in from my not-needed phone and all is OK. Will be working on getting Verizon to recognize that the IMEI for LB1120 should be valid.
