kalbairav
Aug 30, 2023Follower
4G LTE Speed Expectations
I just purchased a 4G LTE SIM card from T-Mobile for my Netgear M6 Pro as I wanted to see what speeds I would get using 4G. On my Laptop connected to my Comcast WIFI I'm getting 374MBps Down and 41MB...
JT240Z
Aug 30, 2023Luminary
Which M6 Pro do you have? Is it the MR6500 AT&T branded version or is it the Netgear branded MR6550? It makes a big difference as to what to expect on the T-Mobile Network. The MR6500 will have limited connectivity on the T-Mobile network. The MR6550 will support all of T-Mobile's bands.
As for the speeds you're seeing with 4G LTE service, that's actually pretty good.
- JT240ZAug 30, 2023Luminary
Forgot it may also be a Netgear M6 MR6150 as well. Just let us know what you have.
