edub4206
Feb 26, 2018Aspirant
4G Modem - LB112X Possible update to 600 mhz Band 71?
Is there any chance this device will be updated to work with T Mobile's 600mhz Band 71?
Audiorulz4u
Mar 08, 2018Aspirant
i highly dought it will be able if the modem it self does not support LTE Band 71. Netgear will have to make a new model that does.. i wish they would make one that supports LTE Bands 2 4 5 12 66 and 71 with Carrier Aggragation and the ability to select which LTE bands you want to use withen the modems GUI plus the Ethernet Output thats found on the LB112x
- edub4206Mar 13, 2018Aspirant
Audiorulz4u, I agree with all your wish lists items, but I am hoping since I am using an external antenna that it is just a firmware update to recieve the 600 mhz band.
- Gbarker45Jul 06, 2018AspirantDid they ever answer you. Would like 600mhz too.
- Audiorulz4uJul 08, 2018Aspirant
This model does not support LTE Band 71 (600mhz) and never will... Netgear will have to make a new model that will support it.. but it would be nice if they did make one that will Support LTE Bands 2 4 5 12 13 17 25 26 41 66 and 71 with LTE-Advanced Support.. that way it could potienal work across all Carriers LTE Networks.
