edub4206
Feb 26, 2018Aspirant
4G Modem - LB112X Possible update to 600 mhz Band 71?
Is there any chance this device will be updated to work with T Mobile's 600mhz Band 71?
Audiorulz4u
Mar 08, 2018Aspirant
i highly dought it will be able if the modem it self does not support LTE Band 71. Netgear will have to make a new model that does.. i wish they would make one that supports LTE Bands 2 4 5 12 66 and 71 with Carrier Aggragation and the ability to select which LTE bands you want to use withen the modems GUI plus the Ethernet Output thats found on the LB112x
edub4206
Mar 13, 2018Aspirant
Audiorulz4u, I agree with all your wish lists items, but I am hoping since I am using an external antenna that it is just a firmware update to recieve the 600 mhz band.
- Gbarker45Jul 06, 2018AspirantDid they ever answer you. Would like 600mhz too.
- Audiorulz4uJul 08, 2018Aspirant
This model does not support LTE Band 71 (600mhz) and never will... Netgear will have to make a new model that will support it.. but it would be nice if they did make one that will Support LTE Bands 2 4 5 12 13 17 25 26 41 66 and 71 with LTE-Advanced Support.. that way it could potienal work across all Carriers LTE Networks.
